I'm Not Sure If You'll Hate Me or Like Me For What I'm Doing!
Old 10-18-2013, 09:50 AM
Pure Automotive's Avatar
Default I'm Not Sure If You'll Hate Me or Like Me For What I'm Doing!
Hey All,
My name is Brady, I'm a shop owner form Maryland. I joined here to do research and get feedback for my new project.
My shop does import and domestic performance work, but my car is actually an import. I have a 2013 Scion FRS. It was 450whp turbocharged on the stock motor, but I sold everything including the drivetrain and ordered an 07 CTS-V Complete Drop Out!
I've started the engine build and all the conversion of the car, I'm not the first guy to do this swap, but I'm pretty sure I'm the 2nd.
The Build
Gen IV LS2 from 2007 CTS-V
Cometic Head Gaskets
ARP Head Studs
Heads Have Been Cleaned and Had Fresh 5 Angle Valve Job
FAST LSX-R 102 Manifold
Comp Cams Timing Set
Comp Cams Lifters
Comp Cams Upgraded Roller Trunions
Comp Cams Pushrods
PRC Titanium Retainers
PRC Dual Valve Springs, Seats, and Locks
Comp Cams LS-R 281LR HR13 Cam
Converted to 3 Bolt Style Cam and Timing Components
Stock Short Block
Tuned on HP Tuners
Car Weighs 2700 lbs, 2905 With Me in it
The Rear End in the car is 4.10
Will be running 275/40/17 ET Streets
Has Full Coilover Suspension
The only thing I haven't bought yet is a clutch and flywheel setup, any input would be great!
Anybody have a wheel horsepower range they think I should fall into with that setup?
Thanks for reading, I'll be posting pictures as the build continues!
Old 10-19-2013, 04:50 AM
Sinister_Z28's Avatar
I run a Monster Stage 4 clutch with a OEM spec billet flywheel. I like it and it holds onto my 408 reall nice.
Old 10-19-2013, 04:56 AM
Sounds like a cool project. I use a Monster Stage 4 clutch with a OEM spec billet flywheel and i like it. Oh and its behind a 408cid engine.
Quick Reply: I'm Not Sure If You'll Hate Me or Like Me For What I'm Doing!
