5th Gen Twin turbo kit
Old 10-18-2013, 03:57 PM
granatelli sales's Avatar
Default 5th Gen Twin turbo kit
A detailed break-down of the 2010-2011 Camaro Twin-Turbo kit and its components are as follows:
2 x PTE6265 Turbochargers with 4” Inlet Compressor ducting – Each capable of 65 lbs/min
Turbos are V band mounted on inlet and outlet to insure easy rotation, solid mounting and best of all there are no nuts and bolts entering or exit turbo body
2 x PTE 46mm Waste Gates Insure Maximum Control Over the Monster
Turbos. Waste Gates Include Adjustable Springs to go from 4.5psi to 15psi (We factory set them at 7lbs)
All stainless steel and Heat temperature coated exhaust system components ensure a lifetime of reliability
1 x 50mm Tial Blow Off Valve
3 x Largest Front Mount Intercooler are Hi flow Bell cores with 3.5” inlets from turbos and a single 4” discharge pipe feeds direct to the throttle body. Intercooler Tanks are Black Powder Coated to Extract Heat Yet Fins Remain Untouched
Fiberglass Reinforced Silicone hose couplers ensure durability for year to come – no expense was spared
All the necessary Vacuum ports required to assist in installing the boost controller
1 x Oil Scavenge Pump & Brkt
Thermal Heat shielding for all effected lines
GMS Oil Feed & Return Line Kit are all precision clamped and crimped to ensure leak free connections
GMS/TTi 3.5” 6061 Aluminum Intercooler Tubing for lighter weight and better heat dispersion
GMS/TTi 4” 6061 Aluminum Charge-pipe
GMs/TTi 4” Aluminum Intake Tubing w/K&N Filters and K&N “Hydro Shields” for extended dust/dirt/water protection
GMS/TTi Aluminum Lower frame cover to ensure debris free road travel
The only TT kit that does not hang below the frame rail, ensure plenty of ground clearance
AEM Windshield Washer Bottle & Accessories
Polished Oil Cap w/oil return
Retains Factory Engine Cover
We offer many options from short blocks and long blocks to various turbo size upgrades and color choices. Factory Silver Powder Coated Tubing – Special
Colors Available on Request.
CALL 805-486-6644
for MORE information
Here is a video dating back to Jan 2010. Naturally we make more power now
This pictures shows our kit installed with a TVS2300. We offer it as a compound boost set up as well. These pictures show the kit better with the engine on the stand
Please note below how OE this kit is once complete
I agree if you want only eye candy this is not perhaps the most flashy. But if you want the max amount of power per pound of boost and only the best will do...you can't beat this kit for fit, finish and the way it just works
This is the power you can expect out of the box - as shipped. Or just keep turning up the boost all the way to 1200hp.:thumbsup:
We all know a stock motor can't go that high and we are not saying that. If you install this kit the power allows you to go from 500 to 1200. You will not need to spend more money on pulley changed and exhaust upgrades
Old 10-18-2013, 04:03 PM
Old 10-28-2013, 04:29 PM
Old 11-26-2013, 01:07 PM
BLACK FRIDAY SALES
Shopping on Friday, November 29, 2013 customers will save 35%.
Shopping on Saturday, November 30, 2013 customers will save 30%.
Shopping on Sunday, December 1, 2013 customers will save 25%.
Shopping on Monday, December 2, 2013 customers will save 25%.
CLICK HERE TO START THE SAVINGS www.Granatellimotorsports.com
Old 12-05-2013, 01:19 PM
Old 12-05-2013, 02:54 PM
LS1Tech Sponsor
Slowhawk's Avatar
Nice looking setup.
Old 12-05-2013, 03:40 PM
bigti99a's Avatar
jesus, 1k ft lb at 2500. nice!
Old 12-05-2013, 05:17 PM
We now are making more power now still looking for more we should have the engine video up by new year
Old 05-20-2016, 10:42 PM
Granatelli's Avatar
Flashback - BTW just got the 2016 Gen 6 TT kit here we come
Old 05-27-2016, 01:19 PM
Old 07-25-2016, 06:24 PM
bump
Old 09-01-2016, 06:42 PM
If your looking to make 550 - 1200hp here you go 20%off this month on turbo kits PM for pricing and shipping to your door
Old 09-08-2016, 12:45 PM
BIG SALE come up on our turbo kits pm for prices shipped to your door
Quick Reply: 5th Gen Twin turbo kit
