GF822 Fittings & LS1 Fueling
Im after some help for my LS1 Into 64 Impala conversion..
Have bought a "Tanks Inc" injected fuel tank with new sender and intank pump cradle with a walbro pump.
I bought a AC Delco GF822 Corvette inline regulator/filter to allow me to run one fuel line from the rear of the car to the engine.
Now the filter has a inlet and return fitting attached but the outlet has a female hole and no fitting. Where can I get this fitting from? Have done a search on the net and cant seem to find it.
Also what size fuel line should I have from the pump to the engine, engine will be stock GTO ls1 with a 232/234 cam, full exhaust incl headers and a ecu reflash.
Thanks in advance!
Thanks in advance!
thanks for that,
how do i attach the fitting to the outlet? as my outlet has a female fitting? Does a hard line just "push" on to the new fitting and then to the filter at the other end?
Mr. West did you ever find out what fits in the female end that runs to the fuel rails? I'm looking for a fitting out of the filter that goes to a flared pipe fitting.
