1998 Jeep Grand Cherokee Laredo (ZJ)
Year: 1998
Make: Jeep
Model: Grand Cherokee
Price: $4500
Mileage: 169000
Private or Dealer Listing: Private Listing
Location (State): IL
Color: Black
Transmission: Automatic
Drivetrain: 4WD & AWD
LS Engine?: Car has LS engine
I am putting up for sale my 1998 Jeep Grand Cherokee Laredo (ZJ). It is time for me to move onto something else. I am looking to buy a car with better gas mileage and a stick shift.
I am the 3rd owner of this Jeep. The first and second owner was my really good friend and his family. I have all the paper work and maintenance logs that I have created when I bought this Jeep in January of 2010.
As far as options goes, this Jeep has dual power seats, power doors, power windows, moon roof / sun roof, heated seats (both work), OVHD display that all read outs work perfectly. I put in an aftermarket radio and speakers. I put in an Alpine CDA-9886 radio and alpine speakers.
There are some rust spots as Jeeps are notorious for this. Have a little bit of rust that has bubbled up on the hood and the front passenger rocker is has some rust as well. Just adds character!
Email me for more details on the Jeep, or if you need any other information just let me know. If you’re local we can set up a time for you to come and look at the Jeep.
Performance for 6 cyl:
Base Engine Size: 4 liters Base Engine Type: Inline 6 (242 CI)
Horsepower: 185 hp Max Horsepower: 4600 rpm
Torque: 220 ft-lbs. Max Torque: 2400 rpm
Maximum Payload: 1150 lbs.
Fuel Data:
Fuel Tank Capacity: 23 gallons
EPA Mileage Estimates: (City/Highway) for 6cyl
Automatic: 15 mpg / 20 mpg
Range in Miles: (City/Highway)
Automatic: 345 mi. / 460 mi.
Please, Serious Inquires Only!
Thanks
-Jonas
169k Miles
Asking $4,500 OBO
Engine
- Bosch “703” Injectors (Injectors were all rebuilt- new filters, o-rings and pintle caps)
- Autolite Platinum Spark Plugs
- Magnacore Spark Plug Wires
- MSD Ignition Coil
Exhaust
- Rugged Ridge Header
- Exhaust was stepped form 2.25” (factory) to 2.5” (all exhaust pipe is 2.5” from the header to the tail pipe)
- MagnaFlow Metallic Spun Cat
- Magnaflow Stainless Steel Muffler
- Magnaflow Stainless Steel Tip
Intake
- WJ Intake
Driveline
- D30 Front Axle
- D35 Rear Axle
- Stock 3.55 Gears
- NP 242 Transfer Case (Selec-Trac)
-42RE: 4 spd. Automatic Transmission
Suspension
- New STOCK Front Isolator
-New STOCK Rear Isolator
- Crawler Ready 2” Coil Spring Spacers
- Skyjacker Front Shocks
- Skyjacker Rear Shocks
-16x8 TJ Moab Wheels
-245/75/16 Goodyear DuraTracs
Misc. Parts
- Rugged Ridge Front Tow Hooks
- CURT Class III Hitch w/2” Receiver
Maintenance Info
Jeep Maintenance
Here’s All The Maintenance That I’ve Done Since I First Bought The Jeep In 1/2010
2 Sylvania Silver Star Headlights (1/2010)
Replaced Rear Struts For Rear Hatch (2/2010)
New Front Sway Bar End Links (2/2010)
New Rear Sway Bar Bushings (2/2010)
Transmission Flush With New Trans Filter (2/2010)
Coolant Flush (2/2010)
T-stat and Gasket (2/2010)
SkyJacker Shocks (when I did my Crawler Ready 2" BB lift) (3/2010)
Drained and Filled Both Front/Rear Dffs (4/2010)
Drained and Filled TC (4/2010)
Replaced EVERY Light On The Exterior (5/2010)
Replace All 5 u-joints (6/2010)
New Brakes Front/Rear (6/2010)
New Rotors Front/Rear (6/2010)
New Duralast "GOLD" Battery (10/2010)
Replaced Front U-Joints and DC. Re-Balanced Front Drive Shaft (8/2011)
Goodyear Wrangler DuraTracs (245/75/16) (10/2011)
Kolak Ign Tune-up (Plugs, Wires, Cap/Rotor - MSD Ign and Ign Wire) (11/2010)
New Rear Wiper Motor (12/2011)
New Rear Wiper Arm (12/2011)
New Power Steering Pump (3/2012)
New Power Steering Pulley (3/2012)
New Serpentine Belt (3/2012)
WJ Intake (7/2012)
“703” Injectors (7/2012)
New Rugged Ridge Header (7/2012)
New Valve Cover Gasket – Fel-Pro (7/2012)
New Front CCV Elbow (7/2012)
New Rear CCV Elbow (7/2012)
New 2.5” Exhaust (From The Header To The Tail Pipe – all is 2.5”) (8/2012)
2.5” (Inlet) x 2.5” (Outlet) MangnaFlow Metallic Spun Cat (P/N 59926) (8/2012)
2.5” (Inlet) x 2.5” (Outlet – Offset) MagnaFlow Stainless Steel Muffler (P/N 12256) (8/2012)
2.5” (Inlet) x 3.5” (Outlet) MagnaFlow Stainless Steel Angle Cut Tip (P/N 35143) (8/2012)
New Water Pump (4/2013)
New Radiator (4/2013)
New Tie Rod (10/2013)
New Tie Rod End (10/2013)
New Drag Link (10/2013)
New Steering Stabilizer (10/2013)
WJ Intake (7/2012)
