Oil drains in a 5.3 twin turbo build. How do I weld in AN fittings
So I just got the 5.3. I'm getting an LS1 pan for my thirdgen swap. I want to install the AN bulkhead drains in the pan. Do they make aluminum fittings to weld to aluminum? I have only seen the steel ones
A bulk head fitting is one that sandwiches the pan between the fitting right? Would it come loose or leak over time?
LT1Ray- I like the 90 degree fitting with the barbs. Any chance you have a part number handy?
