+Awesome deal on AEM Meth Injection kits!+
Sorry, these Meth kits have sold out!
http://www.saccitycorvette.com
PRODUCT FEATURES
1 Gallon tank with built in low level switch
Boost referenced progressive controller
“Boost Safe” readiness safety system
Check valve integrated into nozzle to prevent unintended fluid flow
One injector and two nozzles to cover a wide range of HP levels
High Pressure 200psi Recirculation-style pump
Progressive Controller: Start Injection Boost 1-11psi. Full Injection Boost 6-39psi
LED dash light for system status and low fluid warning
20 ft. of injection tubing
Legal in California only for racing vehicles which may never be used upon a highway.
Note: FOR OPTIMUM RESULTS, ALL WATER/METHANOL INJECTION SYSTEMS AND GAUGES SHOULD BE RUN WITH AN AEM INLINE FILTER (AEM PART #30-3003)
Important Safety Notice Regarding Methanol
AEM strongly recommends that users never exceed a 50% methanol concentration when using any AEM Water Methanol system or component.
All AEM Water/Meth injection systems and components (pump, lines, fittings, filter, flow sensor, tank, and nozzles) are 100% chemically compatible with methanol. However, for safety reasons we strongly recommend that users never use more than a 50% methanol concentration in our systems.
Methanol is a toxic and highly flammable chemical. 100% Methanol ignites easily and burns vigorously with an almost undetectable flame. Methanol can be absorbed through the skin and even x-small amounts can cause blindness or even death. Using this fluid at high pressures, without dilution, in an under-hood environment with nylon lines and push-to-connect fittings is very unsafe. The performance advantages of using greater than 50% methanol concentrations are x-small, if they exist at all. However, the safety issues are very real and far out weigh any perceived benefit of running high concentrations of methanol.
WARNING!
Improper installation and/or adjustment of this product can result in major engine/vehicle damage. For technical assistance visit our forum athttp://forum.aempower.com/forum/index.php or visit our dealer locatorhttp://www.aemelectronics.com/dealer_locator.php to find a professional installer/tuner near you.
Note: AEM holds no responsibility for any engine damage or personal injury that results from the misuse of this product, including but not limited to injury or death caused by the mishandling of methanol.
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
What a deal!
__________________
