Help with tach signal
This is the last thing left on my swap.
2005 5.3 into 1990 240sx. Apparently you can connect C2 #10 engine speed (tach) wire directly to my twin cam tachometer & it will work correctly. As per every other LS 240 owner on the internet.
This does not work for me. With a voltmeter on the #10 wire, it is only showing around 1/20th of a volt (.05 -.07) & the tach needle doesn't move. My harbor freight obd2 scanner shows the RPMs correctly though.
Any advice? The engine & computer came out of the same truck. Tach was working when pulled.
