08 LY6 6.0 mated to T56??
Old 10-31-2013, 10:00 AM
radtexas's Avatar
Default 08 LY6 6.0 mated to T56??
I have 08 LY6 and wanted to check what will be needed to mate a newer style T56 to it? I am still looking for a T56 but is there anything special or will it be the same flywheel clutch setup as a LS1 setup? Can I use any clutch with it such as maybe an LS7 clutch setup. Or even an http://www.ebay.com/itm/C6-CORVETTE-ZR1-LS9-CLUTCH-PRESSURE-PLATE-FLYWHEEL-KIT-NEW-OEM-GM-6-2L-/260881285912?pt=Motors_Car_Truck_Parts_Accessories&hash=item3cbdbc8318&vxp=mtr?
New to LS world and really the bowtie world as I have a 67 Camaro rs vert build I have undertaken.
Old 10-31-2013, 10:50 AM
SNLPerformance's Avatar
What bellhousing and hydraulics do you plan on using?
Old 10-31-2013, 11:01 AM
radtexas's Avatar
I have nothing other than engine at this point. I don't plan on going extreme with HP maybe 500 fwhp at this point. I may try to stick with the f-body stuff but nothing is set in stone. All depends on what I find to work and what deals I may be able to find. If I sound vague it is because I am.
Quick Reply: 08 LY6 6.0 mated to T56??
