Speedometer in a 51
Old 11-01-2013, 09:49 AM
51 chevy's Avatar
Default Speedometer in a 51
Ok guys i picked up my new gauges for my 51 truck, old analog gauges. (I like the original look) I see the place for my speedometer cable. The 4l60e transmission has an electrical plug that feeds into the wiring harness. (ls-1) 4.8 liter engine. How do I get the conversion from the harness to the cable ?? I have wire on my harness for the speedometer hook up, the vss is already in the transmission and running inot the harness?? How does the two match up.
Old 11-01-2013, 10:26 AM
99ssleeper's Avatar
These are your best bet...
http://shiftworks.com/tailhousing.htm#4L60e
http://www.jagsthatrun.com/4L60_Order.html
Old 11-01-2013, 10:33 AM
bczee's Avatar
You can also try the Abbott Cable-X, But there is not cheap solution, Might also look into GPS Speedo's
http://www.abbott-tach.com/cablex.htm
BC
Old 11-01-2013, 04:25 PM
PlayersZ28's Avatar
Dakota Digital makes an electronic to cable converter box.
http://www.dakotadigital.com/index.c...rod/prd886.htm
Quick Reply: Speedometer in a 51
