zl1 intercooler pump pigtail
LS1Tech Sponsor
ZL1 pump connector
The last time I checked (a month or so ago) GM still didn't have the service connector available for the ZL1 pump.
These are the part numbers from the GM service information:
•OEM Connector: 9408621
•Service Connector: 19300589
When we did the ZL1 pump testing we made our own jumper harness in order to be able to do the testing and connected directly to the terminal pins.
I think the Volt uses a similar pump (same connector) for electronics cooling but it doesn't show a service connector part number.
The only place I have seen the connector for sale is on the GMPP LSA crate engine harness (expensive way to get it).
Hope this helps.
Hope this helps.
