MSD wires on stock wiring route?
Old 11-02-2013, 04:58 PM
93Euphoria's Avatar
Default MSD wires on stock wiring route?
I know this topic has been beaten to death but not my specific question.
Anyways I have a quick question about MSD ignition in the near future. I have some cheap summit ones (Blue) on the car now and there were a pain to get to seat on the passengers side trey supporter(whatever its called) and a pain to get the clip on without popping off. They are 7.5mm IIRC, bigger than stock and smaller than the MSD’s 8.5mm. Question is would I need to reroute them since I highly doubt the MSD’s will fit in that trey supporter? Without that they will rub on the belt.
Not only is that my concern but im looking for a wire that has the best Voltage resistance.
MSD billet Opti is coming when either the Delco Unit craps out or when I pull the motor apart for a rebuild.
Old 11-02-2013, 06:10 PM
BALLSS's Avatar
I have Magnacore 8.5 routed through factory looms & btackets, no issues
Old 11-03-2013, 07:00 AM
leadfoot4's Avatar
I'm running Moroso's "Blue Max" pre cut wire set, and I've routed the wires through the OE looms and brackets with absolutely no issues.
Old 11-03-2013, 03:01 PM
93Euphoria's Avatar
You guys had no issues with the clip that holds them in place? I would imagine with 8.5’s it would take some time getting it to fully clip.
Old 11-03-2013, 04:25 PM
leadfoot4's Avatar
Which "clip" are you referring to?
Quick Reply: MSD wires on stock wiring route?
