Windmill's 5.98 pass...video inside
Here you go Monk...Apparently I was a little shaky lol, but here it is.
http://www.youtube.com/watch?v=Jtboo...ature=youtu.be
In-Zane Moderator
Not too hard when everything is right. My lower compression and 3.73s as well as the tight Revmax converter are holding back a ton. The Trans brake in my future with 4.10s and a converter made for this car with some porter 799s should get me where I want NA. Then I'll throw the dope at it again.
Well its sunday one more time,,, going to try some timing on motor,, we drop from running 35 to 30 and made really no diff in et's one 1 in 60ft and 2 at finish line,, but was better weather... so we going to drop some more on timing and test some more on motor passes,,,i know when it was all stock it like the 40 deg timing,,, but now with tick's cam I don't like as much... so will post results tomorrow,,, im going to try some 100 shot pills and see if I can get into 5's with 100 shot..
