Help me choose a ps pump
I've been having issues with my power steering for a while now. When I got the car it had a reman. one on it, leaked on the alternator until it stopped working, got the alternator rebuilt and put a new reman. on it. About two drives later yhe seal pushed out of the front of the ps pump and made a big mess under the hood. Took it off and pressed the seal back in and drilled and set screwed it in. Haven't had a problem for about 3 months but its had a whine since then. On the way back from the track the other day my power steering would work on and off and there's another leak again......should I go with a new ac delco one or what? Turn one?
I'd get a New not remanufactured one.
There's only about a $15 difference between a new GM ps pump(about $235) and the TurnOne($250), and the TurnOne come with a new reservoir and cap, the GM pump doesn't. FYI, the TurnOne pumps slower and prevent overheating the fluid, and less heat means a longer pump life.
PM sent.
PM sent.
Heey man got the pm and thanks for letting me know so quick. Yeah the remans are junk and then was about to buy a new ac delco one and clicked on info and it still said reman! That why I decided to ask about the turn one ps pump after I seen agearheads video. Looks like ill be going with that one then, thanks a lot.
