flaming river rack and pinion
I have a flaming river fr40022 power rack. It has 9/16-18 threads on the inner tie rods, flaming river does not make tie rod ends. I need outer TRE with 9/16-18 threads and the taper for a gmc s-10. I found es3455 at advance auto, with the correct taper but with m14x1.5 threads Anybody know where I can Look. thanks
I think anybody with knowledge is at the sema show. I was told by the tech line they did not have them or sell them. then searching I found these!! http://www.flamingriver.com/index.ph...6/s0001/FR1603
http://www.jegs.com/i/Flaming%20Rive...R1601/10002/-1
http://www.flamingriver.com/index.php/products/c0016, none have a gm taper. guess I'll have to ream the spindle.
My spindles taper from top to bottom (4wd s-10) !!! and the tie rod nut is on the bottom or I would use these. http://www.spohn.net/blog/2011/11/16...r-gm-spindles/ thanks for the reply.
