Fuel pump upgrade
Old 11-08-2013, 04:47 AM
BLK93TA's Avatar
Default Fuel pump upgrade
Looking for a strong direct replacement fuel pump. Suggestions?
Old 11-08-2013, 06:10 AM
RamAir95TA's Avatar
I'd recommend a stock replacement pump.
Old 11-08-2013, 11:54 AM
marc1130's Avatar
Walbro 255lph pump with the strainer and wiring kit, I've been running mine for several years, I used the trap door method to access the tank - no problems at at all.
Old 11-08-2013, 10:13 PM
BLK93TA's Avatar
Know about what hp that's good for? I'm actually in the middle of a LS swap excited about it wanted to change the pump while it's in the air. I've seen the trap door method seems easy enough. What did you seal yours up with?
Old 11-09-2013, 09:39 AM
moderate Z28's Avatar
Cork gasket and a bunch of screws here.
Old 11-09-2013, 11:36 AM
Village Troll
SS RRR's Avatar
Sheet of 1/4" aluminum with self tapping screws as well as a bead of sealant.
Old 11-09-2013, 12:54 PM
Sealant would be better, but I was chasing down a vapor issue at the time so I used cork incase I had to keep removing it.
Quick Reply: Fuel pump upgrade
