700r4 trans on a ls1 convert for temp!
Hey guys i need help. my 4l60e transmission needs a rebuilt but i lost my job so that means i cant rebult my transmission until i find another job but i need my car. i have a 700r4 transmission laying around. can i install that in my ls1 camaro.. its a 2002 with 118k miles. what do i need to install that into my car. thanks for reading
Most likely well need the PCM flashed to delete all of the 4L60e codes and rig up a TV cable on the TB...
Why not just look for a use trans...might cost a bit, but will do away with having to spend for someone to ref lash the PCM two time and the cost of the T.v setup.
BC
BC
I second that recommendation. Installation of a 700R4 will also require a rework of the trans crossmember as the mounting pad location is about 2" further forward than the mount location on the 4L60 trans.
yeah thats true. sounds like a big hastle. since im doing this on my own. man! that sucks. i really didnt wanted to spent all i have left. well i guess im just going buy a rebuilt transmission. wt u guys think about the junkyard. can i return it, if it doesnt work?
Most respectable yards offer at least a 90 day warranty on big ticket items like that. Just ask before you pay.
Have you considered buying some $500 beater to drive until you can afford to fix your camaro?
