Category: Accessories
Price: $1000
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette
Location (State): AL
Item Condition: Used
Engine: LS1/LS6, Small Block
LS Engine?: Fits LS Engine
These heads have ferrea 2.02 intake valves, and 1.57 exhaust valves. They are set up for a solid lifters cam. The springs are crazy heavy and if you want to put in on a hydro lifter set up need diff valve and springs. The retainers are to big and the valve is to long. If you want the heads with out valves and spring 800$. The retainers are ti. Or if you want cam that is intake lift of .734/ exhaust 7.34, solid lifters and shaft mounted rockers. Two rockers will need to be replaced tho. 1800 for all 209-985-3381
