Meth thru a Nitrous plate
I have been planning on running a 100-200 shot. I have been looking at the Nitrous Outlet 2 stage 90mm plate since it was only $50 more than the single stage plate. Then it hit me- run meth thru the 2nd stage ports on it....What would I need to do to get the meth to spray efficiently thru the nitrous jets, ie what size jet would I be needing? I want the meth to kick in at WOT above 2500rpm regardless if the nitrous is spraying. The engine will be between 525-550rwhp before the meth and nitrous.
