FS:2003 50th Ann. Torch Red Z06 Boost ready
Year: 2003
Make: Chevrolet
Model: Corvette
Price: $1
Mileage: 72444
Private or Dealer Listing: Private Listing
Location (State): WI
Color: Red
Transmission: Manual
Drivetrain: Rear Wheel Drive
Here's a video walk around of the car idling.
Dyno tune by Late Model Throttle. Car make 401hp/384tq all motor.
Engine:
TMS build, GM LM7 Block . 3.905 bore, Blueprinted, zero decked, Diamond pistons -2 cc valve relief, Molly rings, Scat H beam rods, GM 24x crank, custom 234/236 cam 114lsa+1, Melling HV oil pump, LS7 T.Chain
Light port 317 heads w/Brian Tooley .660 springs, LS7 lifters, ARP head studs, MLS HG's, Comp 7.4 push rods Compression: 9.6:1
MODS:
-42lb injectors
-Kenne Bell Boost-a-pump
-McLeod RXT clutch
-Hurst Short shifter
-Remote clutch bleeder
-XSPower longtube headers with high flow cats and exhaust..
-RSD Linelock
-R&D Racing Enterprises Roll Bar
-Custom 4 points harness belts on factory seats retaining the factory seat belts
-LAPD Performance Radiator 30% larger than stock
-LAPD Front and Rear frame tow hooks
-Baer Eradispeed drilled and slotted rotors/w Hawk HPS pads(pads is getting low)
-Steel braded brake line kits on all four corners
-Breathless C5R headlights
-Anti-Theft Kill Switch
-Lo-Jack installed
-1-4 shift skip
-Transponder from TCRA
-Iphone or Ipod touch connector to factory Bose stereo
SOLD
Locate in Milwaukee, WI
