NYC fs/ft Turbo LS notch back 9.4@142
Year: 1989
Make: Ford
Model: Mustang
Price: $15000
Mileage: 999999
Private or Dealer Listing: Private Listing
Location (State): NY
Color: White
Transmission: Automatic
Drivetrain: Rear Wheel Drive
tinted head lights
3inch cowl hood
dual 2 5/8 gauge pod on cowl (vacuum/Boost, fuel pressure)
weld pro stars(painted black) 15x3 1/2 (hoosier front runners)
15x10 w/6.5 backspacing (mickey thompson 28x10.5 ET streets)
8.8 rear with svo girdle narrowed 1.5inches in total (.75in a side)
35 spline moser axles wit 5/8 studs
moser spool with 3.08 gears
Double adjustable upper control arms
Single adjustable lowers
Double adjustable QA1 coil overs with Afco springs
Anti roll bar
custom made sub frame connectors
Wolfe racecraft mini tub kit wit frame rail notch
AJE tublar front k-member wit tublar lower arm
QA1 single adjustable coilovers with 12/125lb afco springs
Caster camber plates
AJE tublar tranny crossmember
MOTOR:
6.0 Iron LQ4
ARP rod bolts
Hell Fire rings
LS9 head gaskets
ARP head studs
Ported 317 heads
10.2:1 compression
LS6 cam
LS7 lifters
Lunati Double springs
Master power 76 mm turbo
Tial 38 mm wastegate
RPS blow off valve
Has a muffler under the hood, nice and quiet
TRANSMISSION
TH400 RMVB
Trans brake
Neal Chance 9 “ converter
SFI flexplate
3in drive shaft 1350 joints (nassau drive shaft)
-6an cooler lines with tranny cooler with fan
INTERIOR:
Kirkey seats with black cover
18in driver seat 17in passenger seat
5point harness
B&M pro stick
5inch monster tach,oil pressure,water temp, trans temp (all gauges silver faced)
NGK wide band
10point c/m cage cert to 8.50
FUEL SYSTEM:
10 gal plastic cell in trunk
Magna fuel 4303 pump and filter combo
-12 to pump and -10 to rails -08 to magnafuel regular -08 return
80 Lb / hr injectors
Management:
Megasquirt MS3x (auto tune, closed loop, idle control, 2 step, traction control, boost control)
Stock Metco coils
Tuned on E85
car has never been in a accident all panels are original frame rails are straight as a arrow
The car has run 9.4 @ 142 mph on a baby soft launch and super safe tune, this is a high 8 second car as it sits.
$15,000 or trade for a vette, 335 , m3
