Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Muncie behind 00 5.3?
Old 11-27-2013, 11:47 AM
kodyowenby10's Avatar
Default Muncie behind 00 5.3?
Im going to look at a 2000 5.3 tomorrow and just want to make sure I can use it with my muncie trans with 04ish chevy truck 4.8 5 speed clutch and flywheel from local parts store. I cant find where I read what years there was no flywheel that would fit the crank because of it being longer. I seen some say 99-00 6.0 had the long crank but is that the only one?
Old 11-27-2013, 12:04 PM
In-Zane Moderator
ZONES89RS's Avatar
There is probably an adapter kit for it, but a t56 is such a better choice I would
Never bother.
Old 11-27-2013, 12:15 PM
car is set up with muncie in it so thats what im gonna stay with for now but if the motor wont work with muncie and cheap clutch setup im gonna pass on it
Old 11-27-2013, 12:54 PM
darren roar's Avatar
I think a 621 bellhousing, ls7 pilot bearing and the appropriate clutch for the motor will work.
Old 11-27-2013, 12:58 PM
https://ls1tech.com/forums/conversio...ncie-4spd.html
Old 11-27-2013, 02:06 PM
3pedals's Avatar
It can be done. You don't need that +.400 flywheel either. I got it, but an ls1 flywheel will work fine.
Use LS7 pilot bearing and bbc scatter sheild.
You may need to use a slightly longer release bearing if you use ls1 flywheel, but an adjustable pivot ball can take up some of the slack, and may be enough. I modded my clutch fork to take up the slack.
Old 12-02-2013, 03:43 PM
79CamaroKyle's Avatar
I used an 08 5.3L with the following:
Flywheel: http://www.3guysautoparts.com/searchitem.epc (NFW1050) (3 Guys Auto Parts) $46.58
Pilot bearing to convert LS to muncie: (summit) ($12.97)
http://www.summitracing.com/parts/nal-12557583
Clutch Kit: (Amazon) ($99.20)
Sachs K5552-03 Clutch Kit : Amazon.com : Automotive Sachs K5552-03 Clutch Kit : Amazon.com : Automotive
Hope this helps!
-Kyle
Quick Reply: Muncie behind 00 5.3?
