1962-1965 nova sumped fuel tank and extras
Category: Engine - Intake/Fuel
Price: $850
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): IL
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6, LT1/LT4, Small Block, Big Block
LS Engine?: Non-LS Part
Up for sale is a lightly used Tanks,Inc stock replacement tank for a 62-65 chevy II. It may fit other years but you would have to clarify that. The tank has been modified for a sump, and brackets added for the fuel pump and fuel filter. All of which is included. Please read below for more details.
The tank was painted with POR-15 paint and in all honesty it did not stick very well since I did not scuff up the galvanizing. It still looks nice but there are some areas which will need to be touched up. Color is gloss black. I will include the fuel tank straps as well.
There is a fuel level sender included as well. I am not sure what the ohm range is but I can look in my dominator EFI setup and let you know. I want to say i was 0-90 but will double check.
The tank has had an Aeromotive fuel sump welded in. It does not leak and was professionally done.
It also has a bracket for a fuel pump to hang off of the front of the tank. There are also brackets for a fuel filter welded to the side of the sump.
Both the fuel filter and fuel pump are included.
Fuel pump is a lightly used Holley Billet Dominator 12-1400. The pump has less than 100 miles on it. It works perfectly. I used one of the pumps for continuous use and one of them came on when the car saw boost. This works great and the car made 800 rwhp with this setup.
The fuel filter is an aeromotive fuel shut off style. All plumbing is -10 and the lines from the tank to the filter, and filter to the pump are included. Lines and fittings are all black.
Basically you would need to plumb from the fuel pump to the front and the return line to the back.
New pricing:
$325 for the pump
$200 for the filter
$160 for the sump
$200 for the sump install
$175 for the tank and sender
$100 for misc lines and fittings
Total: $1160 + shipping expense.
Used pricing - $850 shipped. I will have pictures tonight. Please let me know if you have any questions.
