LS3 intake mounting bosses / bolt pattern
Aside from the obvious port geometry differences between LS1-2 and LS3 intakes, are there any notable differences in the intake bolt set up or bracket bosses that might be used for throttle cables or TV cables?
Also, If one were to swap an LS3 intake onto a L92 motor, are there any good flowing factory throttle bodies that are set up with provisions for cables or will work with the Bowtie kit?
Thanks for the help!
Throttle body choices
You won't find a throttle body, of any brand, that's already setup for a TV cable.
https://ls1tech.com/forums/generatio...e-bracket.html
