Notices
Parts Classifieds This an archive of the older parts classifieds, please create a new listing in our Marketplace.
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
NOS Launcher New In Box
Old 12-02-2013, 07:16 PM
Cobra R's Avatar
Default NOS Launcher New In Box
Category: Engine - Power Adders
Price: $350
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V, 67-92 Chevrolet Camaro, 67-92 Pontiac Firebird, Front wheel drive vehicles
Location (State): MD
Item Condition: Brand New
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6, LT1/LT4, Small Block, Big Block
LS Engine?: Fits LS Engine
Brand new in the box NOS Launcher Nitrous controller. This is the base kit and needs a laptop to program.
350.00 Shipped/OBO
email: ttnicolaisen@gmail.com
http://www.holley.com/15977NOS.asp
This is the list of features from the above link
Features
Fully Programmable via laptop
Compatible with Windows 2000, ME, XP, and Vista
NEW innovative NOSbus 2-wire network interface for seamless integration with other Holley/NOS supported products.
Easy to use graphical software
Free software and firmware updates updatable by the user, downloadable off i-net.
Available with a Handheld controller with SD card slot and USB interface for quick changes in the staging lanes and data-logging without laptop in the vehicle.
Available with a 3.5” color, touch screen LCD for the ultimate in programming and looks. (No laptop Required)
3.5” Color, touch screen LCD also features a SD card slot for saving configuration files and data-logging as well as a USB interface.
Full data-logging capability for easy reviewing of past runs through laptop, handheld controller (SD card) or LCD touch screen (SD card).
Ability to save configuration files for easy set-up at different tracks or for weather conditions.
Handheld controller or LCD touch screen allows changes in the staging lanes without laptop.
Fully programmable 2 stages of nitrous control and with the optional slave controller you can add two more stages for a total of 4 fully programmable stages of nitrous control.
Can be programmed to add or take away nitrous at any point to compensate for track or weather conditions.
Integrated TPS for use on fuel injected or drive by wire vehicles without the need of a separate WOT switch.
Two programmable activation inputs.
Activation of nitrous can be provided from a power input, ground input, or a Falling or Rising TPS signal.
Features an internal MAP sensor for nitrous ramps based on boost PSI.
Solenoid control channels with a load capacity of 40 amps for use with large solenoids.
1st gear lockout to prevent the nitrous from being triggered until the RPM cutoff has been hit the first time.
Two 1 amp general purpose outputs for timing retards, purge, or any activation switch (two additional on the optional slave controller).
Use WBO2 controller p/n 15979NOS for rich or lean nitrous cut off. Requires Holley WBO2 sensors p/n 534-198 Bosch or p/n 534-194 NTK (NTK requires a 534-199 extension harness).
Customer has the option to enable lean and/or rich nitrous cutoff with a programmable delay time up to 1 second. Richest/Leanest AFR data is also logged along with the nitrous data for advanced analysis.
Pause Enable Option - when retriggered, (pedaling event) the ramp will continue where it left off (rather than starting over from scratch).
Nitrous pressure sensor input for data-logging.
PROGRESSIVE RAMP FEATURES
RPM based - Programmable Trigger and End RPM points. Adjustable from 0-20,000 RPM
Time Based - Programmable RPM trigger set point, Programmable Delay time and Ramp time, Adjustable from 0-10 seconds
MAP (boost) based - Programmable RPM trigger set point, Programmable MAP trigger and MAP End points, Adjustable from -14.7 to 85 PSI
Nitrous percentage - Programmable start and final percentages, Adjustable from 0 to 100%
Safety features include - Rich or lean cutoff based off of A/F ratios, Nitrous pressure when using a nitrous pressure sensor, MAP (boost) pressure cutoff, RPM cutoff
Attached Thumbnails NOS Launcher New In Box-nos-1.jpg   NOS Launcher New In Box-nos-2.jpg   NOS Launcher New In Box-nos-3.jpg   NOS Launcher New In Box-nos-4.jpg   NOS Launcher New In Box-nos-5.jpg
Old 12-05-2013, 10:22 AM
Cobra R's Avatar
Back up
Old 12-14-2013, 06:36 PM
Cobra R's Avatar
Back to the top
Old 12-25-2013, 09:21 AM
Cobra R's Avatar
Sold!!!!!
Quick Reply: NOS Launcher New In Box
