crankshaft spacer for 5.3
Old 12-04-2013, 01:35 PM
sweenymick's Avatar
Default crankshaft spacer for 5.3
I'm looking to mount a th400 or a 700r4 trans to my 99 5.3 and was wondering what spacer I should go with? Gm has one, part # 12563532 and was wondering if thats the one to get or if someone else has a solution to this problem. Also should I run a sbc flexplate or go with the one that came with my motor. Thanks
Old 12-04-2013, 01:47 PM
gofastwclass's Avatar
You need the Gen III flexplate, not the SBC flexplate. Several people make the spacer, they are all pretty much the same concept with a slightly different design.
A bit of light reading for you... https://ls1tech.com/forums/17524056-post13.html
Old 12-06-2013, 08:26 PM
x275radial's Avatar
I got one from hughes for like 30 bucks and oval'd my holes on the flaxplate.
Quick Reply: crankshaft spacer for 5.3
