What is this plug? L92
Old 12-19-2013, 07:14 AM
Tommy69z's Avatar
Default What is this plug? L92
I was sorting out my harness on my 07 L92 to see what I'm missing due to a couple cut off spots, and I have this plug that is at the front of the drivers head, anyone know what it goes to? Also, where does the maf and alternator plugs come out in the harness? I can't find them so I assume they are cut off. I need an alternator plug, and an O2 sensor plug if some one has a junk harness, and I have an extra harness with most plugs except what I need if anyone needs a plug or two. Thanks!
Old 12-19-2013, 08:19 AM
pdsq98gt's Avatar
That's your missing alternator plug! The maf plug should be a 5 wire plug that is bundled with the a/c pressure sensor plug off of the right front of the engine bay.
Old 12-19-2013, 08:32 AM
Tommy69z's Avatar
So I guess I got the wrong alternator with the motor...mine has the flat 4 wire plug...it was not on the motor at the time I got it...as for the maf plug, I will look again at that part of the harness and see if I see anything cut from that area
Old 12-19-2013, 08:42 AM
pdsq98gt's Avatar
Yea. Some of the newer alternators have only a two prong plug. It might just be easier to buy the 4 prong plug from eficonnection.com or get one from a junkyard than getting a different alternator.
Old 12-19-2013, 08:43 AM
Tommy69z's Avatar
you are correct, looked at the alternator on ebay...plugs match
Old 12-19-2013, 05:40 PM
Tommy69z's Avatar
98gt, I looked again, nothing appears to be cut around the ac connectors. A branch of wires have been cut off near the rear of the intake where it curves around and into the coils and injectors, maybe it was in that bundle...think I have accounted for most everything now
Quick Reply: What is this plug? L92
