98 vette boost reference regulator and line help
Old 12-19-2013, 11:50 AM
Boosted Firehawk's Avatar
Default 98 vette boost reference regulator and line help
Using a ls6 intake and stock fuel rails and lines.
What regulator to use and how to hook it up?
Anyone else have this setup?
Old 12-20-2013, 02:40 PM
Anybody??
Old 12-20-2013, 02:45 PM
Twin turbo c5's Avatar
I use my stock one . 670 to the wheels 14 psi. I have a walbro 255 and 80lbs inj and that's it. no problems for 2 years . and I run the stock reg on my Fairmont with truck rails with no vacuum hooked up.
Old 12-20-2013, 03:18 PM
98^ ?
Whats your psi unhooked vacuum supply?
Old 12-20-2013, 03:31 PM
yeah 98. I've run my reg hooked up to vacuum and without no difference but I always run it hooked up on my corvette. I always kept mine on 14psi never turned it up. But ive run 22psi on my Fairmont with a stock truck fuel reg.
Old 12-20-2013, 05:24 PM
Hmm. I just cant see how that works well enough to not cause issues.
Do u have any idea how much your fuel pressure is unhooked?
Old 12-22-2013, 12:59 PM
ANyone else do this or have this setup?
Old 12-22-2013, 07:42 PM
I never checked the difference on my corvette my fairmont i have and no diffrence plugged or not. I haven't had a issue in two years of running the car. Maybe I'm just lucky. But I've got two turbo cars and both use stock regs. There's many others on here that do the same. Good luck on your build you'll figure it out.
Old 12-22-2013, 07:47 PM
58psi unplugged on my fairmont . It's a return type fuel system like my corvette but with a a1000 pump.
Old 12-27-2013, 11:04 AM
robsquikz28's Avatar
Im surprised nobody else has this setup.
Skinnies I thought?
Old 12-27-2013, 11:23 AM
Have you been on corvette forum and ask some of the corvette guys on there ?
Old 12-27-2013, 09:00 PM
No not yet.
Old 12-28-2013, 05:37 PM
Forcefed86's Avatar
Run it like so, Works great. (return on bottom)
Mallory 4305M FPR
Old 12-28-2013, 07:57 PM
my rail has a feed and return.
that cant happen
Old 12-28-2013, 10:36 PM
Forcefed86's Avatar
Then whats the problem? Run it on the return side like any other return system.
I believe these even bolt in place of the stocker, not sure they flow enough on the return side though.
http://www.ecklerscorvette.com/corve...1997-1998.html
Why not just grab a returnless OEM rail and setup it up like I did above with a known performance regulator?
Old 01-31-2014, 07:27 PM
Anybody else?
Quick Reply: 98 vette boost reference regulator and line help
