HELP! car stuck at 3k after WOT
Old 12-24-2013, 08:54 AM
96LT1Z's Avatar
Default HELP! car stuck at 3k after WOT
Aight so I went and messed around in the car. After I went wot the damn thing stuck at 3k. I pulled over into a turn lane and had to shut it off. After I restarted it and shut it off 3 times it finally idled normal again
Old 12-24-2013, 09:25 AM
bufmatmuslepants's Avatar
Throttle blades could have gotten stuck
Old 12-24-2013, 09:49 AM
MEAN LT1's Avatar
This ^^^
Old 12-24-2013, 10:37 AM
96LT1Z's Avatar
How would that happen? I doubt it was because the spring my TB is real strong. And it's really smooth never gotten caught or anything
Old 12-24-2013, 11:38 AM
96capricemgr's Avatar
What mods are done to the car and what climate are you in?
Old 12-24-2013, 12:22 PM
Kevin97ss's Avatar
Throttle body coolant bypass and cold humid air...I suspect
Old 12-24-2013, 12:28 PM
Fastbird93's Avatar
Make sure the linkage to shaft connection on the TB didn't turn. I had one that did that, very slightly at least so it only caused about a 300-400 RPM difference.
Old 12-24-2013, 01:36 PM
96LT1Z's Avatar
Yep you are right. I'm in Nebraska. It's damn cold right now. And yes I do have throttle body bypass. Is that what would cause that?
Quick Reply: HELP! car stuck at 3k after WOT
