I need some measurements?
Does anyine have the upper aluminum engine mounts and umi upper mounts already bolted together that can measure from the mounting base to the block to the umi hole to the center single bolt hole. Hope that makes sense. I have to make a upper bracket out of steel and I can't seem to find the upper brackets anywhere. Ill get a pic of what I'm trying to make.
