Reuse self adjusting Pressure plate w/new disc?
Old 12-30-2013, 10:06 PM
elesquan's Avatar
Default Reuse self adjusting Pressure plate w/new disc?
I would like to re use my LS6/LS1 pressure plate with a new disc.
From reading some of the threads here, it sounds like these OE type pressure plates are self adjusting.
I assume they adjust to compensate for the disc getting thinner.
So, if I install the fresh disc and the pressure plate is already adjusted itself for a thinner disc, I am assuming I will end up with a clutch that does not disengage.
Will the pressure plate adjust backwards on its own, or is it a one way only?
If they are one way only, is there a procedure to back it off to the original setting while it is out of the car?
I would love to hear from anyone that has figured this out already.
Old 12-31-2013, 01:42 PM
elesquan's Avatar
Default Thanks BRAAPZ!
After searching many threads, I found some great information from BRAAPZ:
How to adjust the SAC;
http://paceperformance.com/files/pdf/zo6clutchadj.pdf
Old 12-31-2013, 02:09 PM
SNLPerformance's Avatar
Not sure what disc you plan on running, but be careful of running an aggressive friction material with cast iron as enough heat can cause it to explode...literally, do a search on youtube for videos if you want to see clutches lodged in dashes. It isn't worth loosing a foot over to save some dough, as an upgraded bell housing will cost as much as one of our clutches that are currently on sale with free shipping.
Quick Reply: Reuse self adjusting Pressure plate w/new disc?
