l76 help from australia!
hey guys know one down here knows what the **** they are doing with L76's
i picked up an L76 dirt cheap with the usual worn out cam, which im replacing with an AFM deletion kit.
im not sure of the powertrain combinations in the states but here they usually have a 6L80E behind them
what im wondering is if i can just use a good old 4L60E (with the larger converter) straight onto the back?
THEN.. im stuck with the programming side, when vats is being removed will the tuner be able to get the TCM to talk to the ECM, will my trans work at all??
the last vehicle even close in australia ran the L76 with the DOD disabled with a 4l60e behind it so im pretty sure shes ok.. thoughts please?
