Another High Idle Thread
So my car has the famous high idle problem but idk what the fix is? I put a ported TB on my car a year and a half ago. Had a high idle every now and then, pretty common no big deal. Recently I took the TB to have it powdercoated. put a stock TB for a week or so then swapped the freshly powdercoated one back on. Now the damn thing idles at 1300+ unless the car is at a complete stop then it drops to 950 which is still high. It used to be around 800.
It idles higher when I go straight down a hill near my house and put the clutch in, rises to about 1800 but it is not based on speed. Even just rolling backwards out of my driveway it rises and that is rolling backwards no help from the trans. My car has the near style hollow PCV valve with the small hole. The car was tuned in September. The problem only started after the Tb was powdercoated. The guy did say he took It apart to powdercoat and I think a problem lies in there.
Any help?
Any help?
Mine was a worn out spring in the tps on the side of the throttle body. Would not let my car idle down .ldled at 1000+ replaced the tps now car idles at around 800
I let a buddy of mine borrow my stock TB so i will get it back and swap it over, thanks for the tips guys
