3 channel to 4 channel ????
Old 01-10-2014, 01:11 PM
johnjohn's Avatar
Default 3 channel to 4 channel ????
Buddy is replacing his rear with a richmond unit. He has offered me his stock 4 channel rear for a good price. It recently had richmond gears put in with a new rebuild kit. It also has the ultimate stud girdle. I would rather just swap out the whole rearend instead of trying to swap chunks. The problem is that I have the 3 channel rear. I've been in to mine and I know it has a relucter wheel to the left of the gear for my ABS. As far as I know the 4 channel has sensors at the backing plate. What and how would be the easiest way to swap the rears with keeping my ABS??
Old 01-10-2014, 03:22 PM
FirstYrLS1Z's Avatar
you can't use the housing unless you have machining facilities.
https://ls1tech.com/forums/gears-axl...-3-w-pics.html
Old 01-10-2014, 05:33 PM
johnjohn's Avatar
Thanks, I tried searching before I posted. Just didn't see that post.
Quick Reply: 3 channel to 4 channel ????
