T56 jolting
T56 jolting
I have a 98 ss with a t56, and I just had the ls7 clutch kit put it about 2 weeks ago. and I've noticed under hard shifts it chatters (like when you have wheel hop) but it doesn't make any sense cause it will do at all the way through 5th it starts more violent but going into 4 or 5th it's not as bad.
That should be enough break in. If it has been just recently you've had the probs, I would check the hydraulics and do a vac bleed. Has the line been drilled out? This could cause a slower apply.
The master and slave were replaced along with the clutch it's going to need bleeding already?
