Whipple off, rethinking my next option
I'm done with my 3.3l, the manifold on that thing is just no good for me.
I'm also sick of paying for tune time with that thing, my only other option would be to one off a new manifold design. I could, but I;m just sick of the thing and want something more bolt on.
Well delema time, I have heads, cam, forged internals and two optoins for a blower.
Eforce, a no brainer, will fit under my hood an strut brace.
2.9 whipple which is now offered for cathedral port heads in corvette belt offset.
Thing is, it sit 10 1/2" from the valley cover, while the mid section will fit under my power dome hood with minimal clearancing, i'm not so sure about the snout. May have to cut up my dome hood and raise the cowl another inch.
Also will have to cut up my beautiful strut brace to modify it too.
My pro and con list,
Whipple- It's a f***n whipple
Whipple looks nicer IMHO
More room to grow with the whipple
Con- more money
Con- more potential modifications.
Eforce pros
cheaper
more plug and play.
It could boil down to whether I would be happy with the eforce limitations.
Con- more money
Eforce pros
cheaper
more plug and play.
Another forum member here has a stock LS3 with only an LS9 cam, his results are quoted below:
I do not think you'll have a problem getting what you're after.
The damn whipple just makes me drool, but I'm not really keen on cutting up my hood.
Going to be honest with you man, why throw good money after bad? There are several of us making good power (sometimes too much) and we pretty much have the kinks worked out. There has not been one engine problem with the E-Force that I know of...more than a few clutch, tranny, or rear problems...but no engine problems at all.
If you go this route, I can give you some good advice on what you'll need to add or steer clear of. Just give me a shout before you buy.
It really sucks you have not been able to enjoy your V for a very long time.
true this, that is why I come here, for someone to lay it on the line for me and set me straight. I am ready to buy, cash in hand.
I will pick your brain, I plan on just the head unit with idler and tensioner.
Does the fuel rail use long injectors or the short ones?
I'm also planing on ditching my current hex and pump, and will go with the ones you used.
I'll also pick your brain on pulleys with my current set up.
You'll need the supplied fuel rails as they secure to the cast manifold, and shorty style SD or LS9 style injectors. The long (OE) style injectors cannot be used...no room. The rails tuck under the upper manifold casting and are a tight fit.
Honestly, the head unit, tensioner assembly, fuel rails, and bolt kit are all you need. You can use the Ford style 2.5 BAR TMAP sensor since you have a 2006, if you can get one without it, I have my take off that I'll never use which you're welcome to.
I am out of town until the end of the week, however I can set aside some time this weekend if you'd like to get all the particulars in order.
Edit: What HEX pump are you looking at? I ended up with the Meziere pump after going through two of the Johnson pieces of ****. You can see it here:https://ls1tech.com/forums/cadillac-...cam-heads.html
I have a 2.5 bar map, from a supercharged cobalt. I thought the shorter style injectors only got up to so big?
So there are 60-65lb sd injectors?
Yeah if you have a parts list I will gladly like the info.
I have the parts list from my E-Force posted here: https://ls1tech.com/forums/cadillac-...ery-today.html
My kit is listed as a universal C6 kit although it is not, it has the Camaro snout installed.
The problem here is that Edelbrock wants to sell these BS "Kits" and the garbage HEX, pump, lines, etc that come with them. I assume the mark every part up 200% and force you to buy them.
Anyhow, you'll need a C6 (LS2) Corvette head unit with the Camaro snout installed and Corvette LS2 tensioner assembly (cannot use the LS3 tensioner unless you use an LS3 water pump). Edelbrock does not sell to customers directly, so you're stuck HAVING to use a vendor. Unfortunately, most vendors know little about anything other than mark up, so it's hard to find someone that can speak intelligently to Edelbrock on your behalf to get you what you need. As a custom order, mine took 5 months to receive. You may be able to contact Edelbrock cust. service or tech assistance to help you order, I got mine when the E-Force was still relatively new and not many knew anything about them.
I sourced mine from Thomas Hendrix, I don't know if he still has a contact there or not. Since he was able to only order the Box 1 kit without all the BS, I only spent about $5200. Thomas mentioned they increased prices at time of my order, which is probably true since that was about the time when Magnacharger raised prices across the board.
There has only been only one other person to market these as far as I know - https://ls1tech.com/forums/cadillac-...ally-here.html
I contacted the guy to ask a few questions and give him some ideas, when he finally did respond he was less than pleasant. Don't know if anyone has sourced one from him or not.
Yes thanks for the info. I'll relook at those threads.
My main other question will be about pulley size. If I remember correctly our builds are much the same. My compession is down to 9.1:1, I do have meth plumbed, but not really interested in pushing it with meth, may or may not even run it.
I would start with the 3.25" pulley, get the tune straight, then upgrade to the 3.0" or OD crank pulley. The 3.25" gives me just over 10 lbs. and about 9 lbs on an LS3. They make 2.75" pulleys, which when combined with the OD crank pulley should be enough for over 800 whp.
I am contemplating an Extreme Composite hood, and may upgrade to the E-Force Chevy Silverado lid for increased volume. If/when I do this, I'll drill and tap the lid for meth and spray the charge air after the rotors, but before the intercoolers for maximum benefit (as meth is designed). The E-Force is the only supercharger on the market (save for OE LS9 units) where this is possible due to the supercharger rotor/intercooler location.
Just food for thought.
Thanks for all the info. I'm sure I may have a couple more eventually.
Did MikeFKSspeed ever come through for anybody?
I've dealt with Hendrix before, and prefer not to do that again.
I too was actually thinking of plumbing the meth after the intercooler, once I see the set up I'll decide where to position them.
Mike dropped off after the RXT group buy. Completely understand your hesitance with Hendrix, everyone that has dealt with him knows exactly where you're coming from. Although I have to admit, he did get me what he promised for the best price going...just wish he could have gotten his act together since he could have been an asset to the LS communities.
It would be hard to spray after the intercoolers since they have to be sealed to the runners below them. Spraying immediately after the rotors will have an immediate evaporative cooling effect and will render the intercoolers more effective. Heat transfer through the intercoolers takes time (one reason why I am looking to replace the lid with the GM truck lid to increase volume, allowing the charge air more time to cool through the intercooler cores) where the evaporative cooling effect is immediate.
There will be time for all of this later...get your **** back on the road already!!!
