hke iron 408 long block ported ls6 heads tr224 cam
Category: Engine - Complete Motors
Price: $4000
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): IL
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
bored .030 over
line hone
set deck height for pistons
balanced rotating assembly
eagle 4340 4.00 crank double pinned crank (comes with no hub)
scat rods I beams 6.2
total seal rings
probe forged (2618) pistons dish 10.5 cc 4.030 1.5 1.5 3.0 mm rings
compression 10.74
arp main studs
double roller chain
ls6 ported oil pump
truck oil pan
comp cams hyd roller lifters (not R lifter)
tfs 5/16 pushrods
patriot gold springs ls1 rocker arms
mls gasket
arp head studs
ls6 head flow
intake
.200 152 cfm
.300 213
.400 256
.500 280
.600 305 cfm
ext flow
.200 112 cfm
.300 152
.400 181
,500 194
,600 206 cfm
cam tr 224-114 .563 lift 114 lsa fast ramp rate
motor is still in car I can start it and drive it if you want to go for a ride. the motor is located in Belleville il (near st.louis) can deliver within 200 mile radius for gas money. 4000 obo text me at 618 five seven eight 8868. I can pull motor fast if needed I have a lift! I have motor build sheets dyno and flow sheets and all invoices but my scanner is not working right now should get it working today. pics coming soon. !!!!!no shipping cash only!!!!
https://www.youtube.com/watch?v=yaG1...ature=youtu.be
