Donor engine?
Old 01-15-2014, 07:19 PM
turbotbirds's Avatar
Default Donor engine?
Just picked up a donor engine out of a 2000 Z71, it is a 5.3. I got the entire engine, harness, computer and all accessories. This is my first LS engine, is there anything "special" I need to do.
It is going to have a 350 turbo transmission, I already got the converter adapter.
How hard is it too modify the stock computer, harness to work in my vehicle? Will it need to be tuned if I don't change cam?
Thanks,John
Old 01-15-2014, 09:26 PM
i r teh noobz's Avatar
The harness is easy to modify if you're not afraid of wires. Lt1swap.com has tons of great info.
The computer will need a VATS delete and emissions delete before it can be started. Tuning won't be needed if its staying stock. I believe you'll want a manual transmission flash to go with the Turbo 350.
Quick Reply: Donor engine?
