Injector? LQ4, 228r, LS6 Intake, LT
What size injector do you guys recommend for a LQ4 with a TSP 228r cam, LS6 intake, 1 7/8" Longtubes, and 4" intake pipe? I've seen mixed opinions. I'm about to purchase a set of 2000 camaro injectors (26lb) and was wondering if these would be big enough? im going to be running a walboro 400lph fuel pump so i could adjust the fuel pressure up if needed. Some say you can run the 26lb injectors to just turn up the fuel pressure, and some say they will be static if you go 100% duty cycle. i guess what i need to know is what % duty cycle will the 26lb injectors be at according to the mods listed? all help is greatly appreciated.
