Power brake boost and trans modulator etc - under boost
Old 01-22-2014, 09:10 AM
69-chvl's Avatar
Default Power brake boost and trans modulator etc - under boost
What happens with these things under boost? I think the brake booster has a check valve, but not sure its strong enough to resist boost. What about the trans modulator?
Old 01-22-2014, 09:23 AM
dschmittie1's Avatar
Your brake booster should have a check valve in it so that it only sees vaccum. Not sure about a trans modulator. It Should at least be able to see atmospheric pressure as that is how it is designed to work
Old 01-22-2014, 10:32 PM
griffsbombelco's Avatar
My brake booster worked fine only thing that sucks is staging the car as I loose vacuum and get into boost I start to loose some breaking power. I also have a th400 that uses only vac and would not shift under boost a tbrake manual valve body fixed that but I'm sure you can find a check ball
Old 01-23-2014, 12:10 AM
PUNISHER TA's Avatar
I have no idea what happened with my car. nor do I really understand how a vacuum boost works, but I can tell you.
When I would take my car out for hard pulls.. The booster would get filled with boost and GET STUCK. Driving home from work a couple times, the brakes would just lock up, I had to pull over and unplug the booster line.
Never figured it out. Going to manual brakes.
Old 01-23-2014, 01:12 AM
RonSSNova's Avatar
Same question about the vac modulator. I'll pink jake shoe an see what he says. You might just post this in the trans section as well.
I have manual brakes.
Ron
Old 01-23-2014, 02:08 AM
SPRAYED 01's Avatar
I ran a one way valve when i had a modulator. Never messed with the boost, always works fine
Old 01-23-2014, 08:44 PM
69-chvl's Avatar
I did search, and interestingly one solution for the modulator is to install a T inline with a check valve, then the boost is vented out. Yes, a boost leak but evidently its such a small amount that it doesn't really matter.
Quick Reply: Power brake boost and trans modulator etc - under boost
