GTO ls1/ firebird t56?
I'm finally getting to the business end of Dads 71 vette brake job turned ls1 swap.
So I got a 2004 GTO motor and 2000 FB t56 together as a combo. The salvage yard actually just tacked on a random t56 to a gto motor and brought it to me. So upon splitting the two, I find they ground out the bellhousing to clear the gto starter (is this common) and there's no pilot bearing in the flywheel. Suspicious about the pilot bearing except that I guess it may have just come out with the original transmission?
My questions are...
Are the flywheel/pilot bearings all the same, gto/fbody/ls1?
Any concerns about grinding the bellhousing and using the gto starter? (it all bolts up ok)
Can I just get a new fbody clutch combo, flywheel and slave, and will it work with the gto starter and will it bolt on the gto motor ok?
Help would be much appreciated!
Bill
My questions are...
Bill
Hey, thanks much. I feel pretty stupid though, should've known it's in the crank. That certainly answers the question though, prob came from an auto trans car, would also explain the extra wiring harness connectors back at the transmission! Any ideas on the starter/bellhousing question?
But the salvage guys did it with the motor/trans close together as there's aluminum swarf everywhere, in the clutch, all over the throwout bearing, flywheel. That was all coming off anyway, but it seemed pretty cheesy to let someone have it that way, especially after spending $4500!
