Is my radiator too good? Temps drop on the highway
Old 01-29-2014, 03:04 PM
the1theycallthe1's Avatar
Default Is my radiator too good? Temps drop on the highway
Hey guys hope you can help....
So i've recently finished my install and i'm having some heat problems.
Whenever i'm parked up - car gets up to temp fine and my rad fan (in front of the rad) kicks in with no problems.
As soon as i get up to speed, or on the highway the temp drops right down, and the temp drops to about 100F (or about 40c).
The rad is a aluminium, I've bled the system and there's no air in it, what could be causing this? Is my radiator just too good?
Here's some pics of my setup.
Any help would be great.
Thanks
Old 01-29-2014, 03:10 PM
fruitsalad's Avatar
Thermostat stuck open?
Old 01-29-2014, 03:16 PM
nofun's Avatar
I second that
Old 01-29-2014, 03:27 PM
thunderstruck507's Avatar
I'm with the above...replace the thermostat
Old 01-29-2014, 03:48 PM
Doh - of all the things not to check.....
Thanks guys.
Part number for LS3 stat? Or are they all the same?
Quick Reply: Is my radiator too good? Temps drop on the highway
