ujoint issue
ujoint issue
Have a acpt shaft bought off rtrigg and his setup was with a 12 bolt I have a 10 bolt no problem bought the conversion joint and went to install and couldn't get it in ..measured the body of the joints and the one that came out is 1/4 inch smaller then the moog one ...anyone know what joint I need or company that acpt uses for the joints the joint has a crown on it with a 2 next to it as 813 ontop 153 next to it and the otherside has USA across it I googled all of these numbers and got Nothin
