Using a 2000 Camaro Z28 IPC in 74 C3 Corvette LS1 Swap
I read in another forum where a C4 Corvette owner swapped his LCD Instrument Cluster for one from a 2000 Camaro. He did not elaborate as to the wiring involved. See what he had done I am considering the same as I can purchase a Camaro IPC for @$50 on eBay. Much less than purchasing individual Autometer or other gauges.
Can someone tell me how a 2000 Camaro IPC is connected / receives input for all the gauges - Speedo, Tach, Volt, Water temp, Oil Pressure, turn signals, etc?
thank you!
thank you!
