FLT 4L60E and Circle D converter
Category: Accessories
Price: $0
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): IA
Item Condition: Used
Engine: LS1/LS6, LT1/LT4
LS Engine?: Fits LS Engine
This transmission will work with the LS cars I will include the flywheel and spacer that are required.
The converter is a Circle D 2c 3600 stall for nitrous, drives great and hits hard. Ive been 1.51 on motor with it and 1.37 on a 100 shot. This converter only has about 1200 miles on it since I had a restall (went from a NA converter to nitrous)
FLT specs:
FLT machined performance pump.
Media blast case, bell housing, and tail housing to restore a new aluminum finish. Prep case for assembly.
FLT sleeved input drum
FLT (billet 6061 aluminum) overrun piston
Sonnax SmartShell w/bearing kit
B/W hi-energy 3-4 clutch pack
B/W double caged 29 element sprag
4L65 low roller clutch
Corvette servo
Alto wide 2-4 red lined band with reinforced anchor
Bushing kit
New solenoids
New Spacer plate
B/W clutches
Seal & gasket kit
Filter
Updated aluminum accumulator pistons
FLT calibrated valvebody with HD 2-3 shift valve modification
Set end play to FLT specs
Case cooler fittings
Its a level 4, the same transmission level Larry from AMS went 9's on. Asking $1850 + shipping OBO, will only ship to a business
I would like to sell together but I will part them for the right price.
Thanks, I payed almost 2500 for the transmission alone back then. Its sickening to sell it for this, but I understand its a used transmission. I couldnt be happier foe the product I received. But with the nitrous I'm running its time to go th400 or 80E.
Will this work for a street car? Doing a 5.3 single turbo build 550-600rwhp. Car will never see track time just street miles. Everyone says not to mess with a 60 and go right for the 80?
I would be interested in just the transmission if you would consider seperating but, if not I may take both, pm me if you would please with a shipping quote to buisiness zip 63114 st Louis MO.
