another lt1 carb conversion
what I have is a 84 chevy caprice as the recipient vehicle. The motor is out of a 95 chevy caprice 9c1. It is the lt1 motor already been verified. I want to convert the motor to a carb setup. Its only going to be driven on occasion and not a daily driver. I have another 95 caprice 9c1 with the lt1 running perfectly in it for fuel injection economy fun. So any one have a list of parts needed with working links to parts sites. I've come across a few sites with the same old parts list to sites that no longer offer the linked part. I'll continue to use the stock 700r4 that was in the 84 as well. The car once completed will only get around 4k miles a year. My daily drivers are a 08 ford cvpi and a 93 chevy pickup.
so again just need a working parts list of what I should / can use and a place to still get them. Thanks
did you read the thread in this section?
https://ls1tech.com/forums/lt1-lt4-m...hat-takes.html
unlike droping in a carb LT1 into a a non MPFI, FI car that has a high pressure fueling system....you will have some modifications to deal with but doable.
Yes I did read thru The Full Carb Swap Parts List And What It Takes write up. how ever not all the links have active parts available when clicked on and just show the part as N/A. That why I asked if there was a current list of what to use.
