4L80 conversion U-Joints
Ok i'm doing a 4L80 swap in my '02 Z28. Stock driveshaft and a 4L80 slip yoke for it. Does anyone have a 100% correct model/brand number for a conversion U-Joint. The rear is easy since it's just the stock setup but the front i need one that works for the stock DS(have to melt the plastic out) and the Slip has the outside snaps. Also I have a question as to how the hell you get the new snaps in on the stock shaft? I've searched for a long time and either i'm searching the wrong thing or there is no real answer to be had
