Are all gen 3 LSX alternators interchangeable
Old 02-03-2014, 09:33 PM
ion05's Avatar
Default Are all gen 3 LSX alternators interchangeable
and can a f body alternator power a vortec motor 4.8,5.3,6.0?
Old 02-03-2014, 10:42 PM
ls1nova71's Avatar
Power it? Yes, but I'm not sure it will fit a truck bracket with the plastic vent thing on the back, as it may be in the way, but you could probably remove it.
Old 02-04-2014, 05:11 AM
Pop N Wood's Avatar
Like noted above they differ in size and connectors but if you build your own mounts you can put pretty much use any alternator. I have a Denso unit off a celica on mine. If you want bolt on then I think pretty much all modern GM alternators except maybe the CTS have the same mounting bolt spacing. There may be some issues with clocking and clearance.
Old 02-04-2014, 10:16 AM
mantycarguy's Avatar
Corvette alternators use different spacing and hookups.
Old 02-04-2014, 10:32 AM
gofastwclass's Avatar
True, regretfully they also have "Corvette tax" applied to them so people rarely use them in swaps unless they had one lying about.
F-Body alternators are "only" 105 amps. (I remember when that was huge)
Truck alternators are 105 or 145 amp depending on the small vs large case.
I use large case truck alternators on all my vehicles unless I can't get it to fit. They seem to be the cheapest and most likely to be in stock at the parts store - and they are the highest output for the money. This also keeps the ability to use the PCM to control the alternator's output intact.
Old 02-04-2014, 10:12 PM
ion05's Avatar
thanks for the replies.
Quick Reply: Are all gen 3 LSX alternators interchangeable
