FS: 42 lb/hr Racetronix Delphi/Lucas Injectors EV1 Connector Part #: 01D030B
Category: Accessories
Price: $225
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V, Front wheel drive vehicles
Location (State): MI
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6, LT1/LT4
LS Engine?: Fits LS Engine
Part number on the injector: 01D030B
Connector Style: EV1/minitimer
Price: $225 shipped
Info taken from Racetronix:
ADDITIONAL INFORMATION
Top feed disc injectors uses multiple holes around its circumference. The disc rests on a short chimney that surrounds a metering hole. As the disc is raised off the chimney by magnetic force, fuel flows through the holes in the disc, over the walls of the chimney, and out the metering hole to form a full, finely atomized cone.
Performance advantages over pintle injectors (i.e. Ford / Bosch & Accel types) as listed by Delphi:
The flat mating surface ensures that no excess fuel is present to evaporate and therefore, no deposits or clogging can occur.
Compatible with alternative fuels (i.e. E85, Methanol)
Longer service life
High-speed disc action allows wider dynamic flow range for improved idling
Quieter operation
Revolutionary disc design resists build up deposits which can affect fuel flow.
No Fuel leakage for quicker starts
Grease supplied to lubricate o-rings prior to installation
