05 GTO TB, Pedal with 12586243 04 Corvette PCM?
I want to use the GTO pedal and LS2 engine / 4L60e with a 12586243 (04 Corvette) PCM because I have a standalone harness that is compatible with this PCM, and tuning seems more available than for the GTO E40 / T42 combination. Will this combo work with a 04 Corvette TAC module?
That's tricky. The '05 GTO LS2 doesn't have a tac module. I think if I were you I would contact an expert tuner or someone like Speartec. Hopefully they can give you a definitive answer.
Right, the CTO ECM processes the pedal directly. So now I'm questioning the TB compatibility with the Corvette PCM and TAC module, even if I used a Corvette pedal.
