6.0 Questions
Old 02-13-2014, 09:32 AM
N2Ojunky's Avatar
Question 6.0 Questions
What all has to be changed to put a 6.0 LQ4 in my 98 Z28 Camaro? I'm going to take out my LS1 because it lost oil pressure and started making a noise. So are there any differences in the LQ4"s? Like what year 6.0"s use the same flexplate as my LS1? I know there are some differences in the cranks or something. Like for example a 2000 LQ4 vs a 2005 LQ4 can anyone shed any light on the differences in them and how can I tell what they are by looking at them. I am in the market for one. Thanks for any help and advice.
Old 02-13-2014, 10:33 AM
Rob WS6's Avatar
2001 and up LQ4/LQ9 have the correct crank. Nothing has to be changed. You drill and tap one hole on the drivers side front of the block for the accessory bolt, and that's it. Make sure not to get 2007 and up because they use a 58x wheel.
Old 02-13-2014, 12:30 PM
N2Ojunky's Avatar
Thanks and 58x wheel is that the flexplate?
Old 02-13-2014, 04:21 PM
iliveonnitro's Avatar
No, that's the reluctor wheel that's on the crankshaft. You can see it when you take off the oil pan.
Old 02-22-2014, 08:34 AM
N2Ojunky's Avatar
Can it be changed over or do I have to stick to one that comes with a correct wheel?
Old 02-23-2014, 06:34 AM
garys 68's Avatar
Get a 6.0 LQ4/9 manual. You'll need it for torque specs and instructions on swapping oil pan, intake, etc. You can find it online.
Swap over all front accessories, including balancer. As pointed out, you'll need to drill/tap one hole
Swap over the intake/injectors/TB, exhaust, oil pan, pickup, windage, dipstick, flexplate.
You'll need new GM balancer and flexplate bolts.
You can screw up any of the above operations, so follow the manual.
Old 02-25-2014, 05:03 AM
40ChevyCoupe's Avatar
You can change it over by swapping to an earlier 6.0 crank. Probably easier to stick with a pre '07 motor.
Old 03-02-2014, 01:16 PM
N2Ojunky's Avatar
My buddy said my headers might not work with the 6.0 is this true?
Old 03-02-2014, 01:21 PM
HCI2000SS's Avatar
The headers from my LS1 bolt right up to my 6.0
Old 03-02-2014, 07:25 PM
Rob WS6's Avatar
Not sure why he said that, as the LQ motors are dimensionally identical to any other LS1/6.
Old 03-02-2014, 10:32 PM
N2Ojunky's Avatar
I think he thought the ports were different.I believe I want a Lq9 seeing how my car will be a motor/nitrous set up. What did they come in? How can i know that its not an Lq4? So when I put a cam in it what springs are good? Also do I have to change pushrods and will the truck coils work in my car? I know I have a lot of questions but thanks for any info and help.
Old 03-03-2014, 10:27 AM
Rob WS6's Avatar
LQ9 came in Escalades, Silverado SS and GMC Denali. If you don't know the vehicle it came out of, the only way to tell the difference is to pull a spark plug and look into the chamber with the piston visible, and see if it has a dish. If its a flat top piston, its an LQ9. There aren't any external differences between an LQ4/9.
Springs will depend on the cam you choose and should be matched accordingly. Once you install the cam, youll need to measure for correct pushrod length. Even if you find, after measuring, that stock pushrods will work, I wouldn't use them. Get a decent set of hardened pushrods, its cheap insurance.
Yes the truck coils will work, all you'll have to do is bend the fuel rail connection line out of the way about a half inch towards the rear.
The only other thing you'll need to do is drill and tap the accessory bracket hole on the front drivers side of the block. Takes about 10 minutes.
Old 03-03-2014, 11:08 PM
N2Ojunky's Avatar
Will a MS3 can work in a stock "piston/head LQ9 ?
Old 03-04-2014, 09:45 AM
"I MAID THEESE"
Mavn's Avatar
Yes, should make good power ^
Quick Reply: 6.0 Questions
